This is a known issue which occurs while running a VI in LabVIEW NXG 5.0 which was originally developed in LabVIEW NXG 5.1. However, you can use the below workaround before running the VI to prevent the crash: 1 - Open your project or VI in LabVIEW NXG 5.0. Refer to the block diagram constants and front panel controls and indicators in each of the VI in your project. You could see some string values automatically inserted into all the controls, constants and indicators as shown in the images below.If you try to delete or change these strings you will notice that these cannot be modified in any way. 2 - Click on one of these controls, indicators or constants. In the Object Properties pane on the right under the Item tab you will see a section labelled as Display format. You will observe that all the fields are by default blank.3 - Click on the first box & select Automatic. You will observe that the string inside your control, indicator or constant is removed.4 - Perform this for all the controls, indicators or constants for all the VIs in your project and save the project. You can now run your VIs without the LabVIEW NXG 5.0 environment getting crashed.
A valid service agreement may be required, and support options vary by country.
