The MP500 supports all of the data rates listed above as of January of 2019, with the release of the firmware version Driver 1.18, FPGA 21.
In order to implement any of the data rates in MPManager, simply use a
Configure step under the ISO 15693 section, and then select the proper data rate in the
Command parameters section as shown below.
In order to choose the desired data rate in your own source code using the
MPuLib API, use the
MPC_AddToScenarioPCD( ) function and use the
TSCN_DO_CHANGE_VC_DATA_RATE parameter, which has the value of 34.
