"The System Cannot Find the File Specified" Error When Running an Installer
Updated Apr 27, 2022
  • LabVIEW Professional
I am running an installer on a target computer and I get the following error message:
The <NI Software> installation has failed with the following error: The system cannot find the file specified.
This error can be solved by running the Installer from a different path. It is suggested that you copy the installer files to a directory with a shorter path than the one from which it is causing the error.
This error can occur when running an installer created with LabVIEW, LabWindows™/CVI™ or other NI software.
