Self-Calibrating My NI PXIe-78xxR Card Programmatically
Updated Jun 9, 2025
  • PXIe-7822
  • PXIe-7868
  • PXIe-7820
  • PXIe-7821
  • PXIe-7862
  • PXIe-7861
  • PXIe-7866
  • PXIe-7865
  • PXIe-7899
  • PXIe-7890
  • PXIe-7891
  • PXIe-7892
The article below explains how to programmatically calibrate the R-Series card.
There are some VI's that were built specifically to be able to programmatically calibrate these R-Series cards. The steps on how to find these can be found in the R-Series Calibration Procedure document. In this document, you can find the location for both the VI's that you can call directly from LabVIEW, or the DLL and header information if you are using some other coding language.
If you have the R-Series driver installed, you can find these VI's at the following location: National Instruments\<LabVIEW Version>\vi.lib\LabVIEW Targets\FPGA\RIO\R Series\78XXR\783XR \Calibration\Public.
It's also important to mention that these VIs run on a Windows Host PC, if this is a PXIe card that is in a chassis with NI Linux Real-Time controller, you can still run these VIs from a Windows PC that has connection to this target controller.
