This issue can occur if the Station ID is manually configured or not set to use the system computer name. Configure the Station ID in TestStand using the following steps:
- Open the TestStand Sequence Editor.
- Navigate to Configure>>Station Options.
- Select the Preferences tab.
- Enable the Use Computer Name for Station ID checkbox to automatically use the system name.
- Alternatively, enter a custom value in the field below if a specific identifier is required.
- Click OK to save the changes.
After applying these settings, generate a new report to verify the Station ID is displayed correctly.
