Custom About Dialog Box Is Not Displaying on My Application Built With LabVIEW
Updated Mar 22, 2021
  • Mac OS X
  • Verify you are using the Use Fast File Format checkbox selected on the Advanced section when building the Application. If that's the case, unselect that checkbox and try building the application again
The steps listed before are not the solution of the issue, it is mostly the workaround for this issue.
Please note that this behavior has already been identified as the Bug 995456.
  • If you have already checked that the option is not enabled and you are still having issues, please contact NI Technical Support.
