Archived:Can I Run Multiple Simulations on Different Designs in MultisimLive?
Updated Nov 11, 2026
  • Multisim Live
Can I use MultisimLive to run two different circuit simulations at the same time while they are on different designs to review the results in the same graph?
MultisimLive can only run both circuits if they are on the same design to review the data together.
You will need to manually copy one circuit into the second design, and then run the simulation. You will be able to see the simulation behavior or results under the same circuit now.
