Error 1 Occurred When Running LabVIEW GPU Analysis Toolkit
Updated Mar 25, 2021
  • LabVIEW GPU Toolkit
Error 1 occurs with the following message when I run LabVIEW GPU Analysis Toolkit on a certain PC. It works fine on other PCs.
lvcuda.lvlib:Set Library Paths from CUDA Bin Path.vi->lvcuda.lvlib:Set Library Paths.vi->lvcuda.lvlib:Get Device Count.vi:1120001->Get GPU Device Information.vi<APPEND>
%CUDA_PATH%\bin
<b>GPU Analysis Information:</b>
Initialization failed.
<b>Cause:</b>
The initialization function failed because the path information did not contain the expected libraries.
<b>Solution:</b>
If the path information is passed directly to the initialization function, make sure it contains the expected third-party libraries (e.g. CUDA Toolkit, CUBLAS or CUFFT libraries).
CUDA Toolkit may be outdated. Upgrading it to the latest version may resolve the error. The latest version can be found in the CUDA Toolkit archive list in the Related Link.
