- When I try to install the Database Connectivity Toolkit as standalone or through the LabVIEW online installer, I get the following error message.
An error occurred while installing a package: ni-labview-2020-database-toolkit (20.0.0.49155-0+f3)
- When I try to install the Database Connectivity Toolkit using the offline installer, the installation fails. The local NI Package Manager logs display the following error message.
-125530: An error occurred while installing the MSI at 'LVDBT00\LVDBT202064.msi'. Error 1919. Error configuring ODBC data source: LabVIEW, ODBC error 11: Driver's ConfigDSN, ConfigDriver, or ConfigTranslator failed. Verify that the file LabVIEW exists and that you can access it.
