Red Exclamation Marks in NXG Conversion Utility
Updated Feb 5, 2021
  • LabVIEW NXG
I am seeing red exclamation mark during the conversion preview of my LabVIEW library to LabVIEW NXG. When I press View Errors, it does not explain what are the errors? How do I check the errors?
The conversion preview will only show warning on the files that will potentially have error when converted. To check the errors, you can proceed to convert the particular files, project or library and they will populate in the directory that you specified. Once you run the .gvi files, you will noticed that the errors will be mentioned at the bottom of the environment stating the error's ID, file impacted and message to describe the error.
If the source code contains features that are not supported in LabVIEW NXG, you may have to modify your new code during migration to replicate the behavior of the original code.
