Does The Rack Mounting Kits for the PXIe-1084/1095 PXI Chassis Include Short and Long?
Updated Aug 6, 2026
  • PXI Chassis
May I know contents of the following 786371-01 and 786372-01 rack mounting kits? Are there two options, one for long and short in these kits?
The 786371-01 is referring to the front mount rack and the 786372-01 is referring to the rear mount rack. Both front and rear mount will include short and long options. You can interchange them depending on your rack size.
