Total Max Power of Three RMC Outputs of sbRIO-9608
Updated Dec 14, 2020
  • sbRIO-9608
SbRIO-9608 has following three RMC output as shown in the block diagram .
3.3 V (0.33 A)FPGA VIO (0-47)
3.3 V (0.33 A)FPGA VIO (48-95)
3.3 V (0.33 A) AUX power output
Can we use all of them simultaneously? Is it possible to draw 0.99 A current from the three outputs in total?
Yes, each of those subsystems is rated to output 0.33 A regardless of what the other subsystems are doing, so there should be no issue with running all of them simultaneously.
