You can use MPManager's
FIRMWARE UPDATE feature to upgrade your firmware. Once you have downloaded the zip file of the firmware version you would like to target, first unzip it to a file location of your choice. Then use the following steps:
- Connect to your device in MPManager
- Click on the Firmware Update tab.
- Click on Open Update Package and load the firmware you have previously unzipped.
- Click on the Update button :
