Setting Custom Baud Rates on NI-XNET Devices
Updated Jul 2, 2026
  • NI-XNET
This article explains how to configure a custom baud rate for CAN or CAN FD communication using NI-XNET. You can either define the baud rate in the NI-XNET Database Editor or apply it programmatically in LabVIEW™ using interface properties.
Before proceeding, ensure you have:
  • A valid NI-XNET database file
  • NI-XNET hardware
  • NI-XNET driver installed
  • LabVIEW (if performing programmatic configuration)
Configure Custom Baud Rate in NI-XNET Database Editor
  1. Launch NI-XNET Database Editor.
  2. Open your database file.
  3. Select the CAN Cluster you wish to modify.
  4. In Cluster Properties, select Custom from the Preset Baud Rate drop-down menu.
  5. Configure the custom baud rate parameters in the available fields.
    1. Calculate timing values based on a 40 MHz clock (Time Quantum is 25 ns).
    2. Adjust values if migrating from hardware with a different clock frequency. For example, if parameters are based on 80 MHz hardware, divide the values by two.
    3. Account for hardware offsets where applicable. For example, if you need a BRP of 2, configure it as 1 because the hardware adds 1 internally.
  1. Save the database.
Refer to Interface:64bit Baud Rate and Interface:CAN:64bit FD Baud Rate for a more detailed explanation of the Bit Timing Registers.
Configure Custom Baud Rate Programmatically in LabVIEW
  1. Open your LabVIEW block diagram.
  2. Place a property node:
    1. Right-click the block diagram and navigate to Measurement I/O>>XNET>>Session Node.
  3. Select the appropriate property on the node:
    1. For CAN, select Interface>>64bit Baud Rate
    2. For CAN FD, select Interface>>CAN>>64bit FD Baud Rate
  4. Copy the hexadecimal value from the custom baud rate dialog in the database editor.
  5. Create a constant or control and wire it to the property node.
LabVIEW Property Node
  1. Convert the value to hexadecimal if needed.
    1. Right-click the constant or control
    2. Select Display Format
    3. Choose Hexadecimal in the Numeric Constant Properties window.
