LabVIEW
You need to use the Reserve Network Device VI found in the
Measurement I/O>>NI DAQmx>>Advanced>>System Setup functions palette in LabVIEW. Specify which device you want to reserve on the
device in input.
The VI below is an example of how programmatically to reserve and perform a self-test in a cDAQ chassis :
Note: When distributing an application that reserves a cDAQ chassis in LabVIEW through the use of an Installer built in LabVIEW, include NI MAX to the LabVIEW-Build Installer following Manually Include NI MAX in a LabVIEW-Built Installer.
LabVIEW NXG 5.0
Hardware Interfaces>>DAQmx>>Advanced>>System Setup functions palette in LabVIEW NXG. Specify which device you want to reserve on the
device in input.
LabWindows/CVI
Use the
AddNetworkDevice function call to reserve the network chassis in CVI.
