Migrating from CAN to CAN-FD using NI-XNET
Updated Apr 19, 2024
  • PXI-8512
  • PCI-8511
  • PCI-8512
  • PXIe-8510
  • PCIe-8510
  • NI-9860
  • NI-XNET
I am able to use XNET driver's properly for Communication Area Network (CAN) communication to DUT ( Device Under Test ) now want to migrate to CAN with Flexible Data-Rate (CAN FD), Is it possible to do using XNET ?
This can be done by following basic steps for modifying the CAN dbc (CAN database file) for working with CAN-FD with help of NI-XNET Database Editor :
1.  Open NI-XNET Database Editor.
2.  Select CAN Cluster and specify the I/O Mode to CAN FD
3Specify the FD Baud rate and Baud rate as per your application as shown in the below NI-XNET Database Editor:
NI-XNET Bus Monitor needs to be configured with the same setting as mentioned above.
