The VeriStand Model Framework is included with the general installer for NI VeriStand. You do not need to reinstall other NI software to install the Model Framework.
If you are compiling a model from MathWorks Simulink® Software, please ensure Matlab 32-bit or 64-bit has been installed before installing VeriStand Model Framework. In order to fully use VeriStand Model Framework,
matlabrc.m installed by Matlab should not be read-only, otherwise it needs to be edited manually. Refer to the
VeriStand help for more information.
For NI VeriStand 2019 or later
- Download and launch VeriStand Installer.
- Under ADD-ONS, check VeriStand Model Framework.
- Continue through the installation process. Once complete, you can find the components installed at RootDrive:\VeriStand\version\.
For NI VeriStand 2018 or earlier
- Launch the VeriStand installer.
- Continue through the installation wizard until you reach the section that allows you to select which features to install.
- Click the box next to the VeriStand 201X Model Framework option and select Install this feature to a local drive.
MATLAB®, Simulink®, Simulink Coder®, and Real-Time Workshop® are registered trademarks of The MathWorks, Inc. All other trademarks are the property of their respective owners.
