- There are two different ways you can choose which OS to boot into:
- Setting the RT Boot Options in the BIOS through the LabVIEW RT Setup Menu
- You can enter the BIOS by pressing the Delete <DEL> button upon boot up.
- If your controller's Boot Configuration is set to Use Switch Setting, then the position of the configuration switch will determine the boot mode of the controller.
- Setting the Boot Configuration to LabVIEW RT will cause the controller to boot into safe mode regardless of the switch's position
- Using the LabVIEW RT Configuration Switches located on the PXI Controller
- This will only work if your controller's Boot Configuration is set to Use Switch Setting.
Note: In order to install LabVIEW Real-Time onto a PXI Controller preloaded with Microsoft Windows, you need to purchase the
LabVIEW Real-Time Deployment License for NI PXI Controllers .
Note: The following controllers have the RT safe mode image built into the BIOS and do not require a separate boot disk for setup and configuration:
- PXI-8101
- PXI-8102
- PXI-8108
- PXI-8109
- PXI-8110
- PXI-8115
- PXI-8119
- PXI-8184
- PXI-8185
- PXI-8186
- PXI-8187
- PXI-8195
- PXI-8196
- PXI-8820
- PXI-8840
- PXIe-8100
- PXIe-8101
- PXIe-8102
- PXIe-8108
- PXIe-8115
- PXIe-8135
- PXIe-8820
- PXIe-8840
