该内容不适用于您选择的语言
Compiling Models for Use With VeriStand Without Development License
Updated Jul 27, 2023
  • VeriStand
  • VeriStand Model Framework
There are times when your VeriStand development or deployment machine may be separate from the PC you wish to use to build your software (such as Simulink) models.
This tutorial will show you how you can build your models without the full VeriStand or LabVIEW software developments installed and without the need for any paid licenses.
The NI VeriStand Model Generation Activation Utility allows you to compile models for use with VeriStand without the full development system. Use the following steps to install and activate this feature.
1. Download NI VeriStand from NI VeriStand Download Page or through NI Package Manager.
2. Launch the NI VeriStand installer.
Now see the relevant section below for your version VeriStand. Once you have finished the section, carry on from step 3 below.
For VeriStand 2019 and later:
a. Click Deselect All to uncheck all products. We do not need the full Veristand environment to just compile models for use with VeriStand.
b. Select VeriStand Model Framework. This component alone allows gives you the ability to build models for VeriStand, but it does not have a separate installer.
c. Select VeriStand Model Generation Support for LabVIEW, if you need to create NI VeriStand Models using the LabVIEW Application Builder. If you are not using LabVIEW for your model, skip this step.
For VeriStand 2018 SP1 and earlier:
a. Select to install NI VeriStand 201x Evaluation - Serial number not required.
b. Select the NI VeriStand 201x Model Framework as the feature to install.
c.  Install the NI VeriStand 201x LabVIEW Model Support, if you need to create NI VeriStand Models using the LabVIEW Application Builder.
3. After successfully installing the software, restart your system (do not launch the Activation Wizard at this time). After rebooting, launch NI License Manager, browse to Local Licenses » NI VeriStand » Add-ons » Model Generation, and activate with the Serial Number S14X86758.
After installing and activating Model Framework and Model Support, you should now be able to develop DLL's in other environments that can interface with NI VeriStand.
The Model Framework allows you to compile models from third-party applications for use with NI VeriStand, while the Model Support adds support for LabVIEW Application Builder. If you aren't using LabVIEW Application Builder, you do not need to install Model Support.
VeriStand 2021 introduces a new method for Simulink integration, VeriStand Model Generation Support. That MATLAB add-on is separate from the model framework used here and this article does not apply to the use of that add-on.
