VisaNS has been deprecated as of NI-VISA 19.0. It is being superseded by
NI-VISA .NET, which should be used for newer applications. You can install support for VisaNS using the NI-VISA 18.5 installer. You will need to select support for VisaNS during the installation process as shown below.
