该内容不适用于您选择的语言
Converting a LabVIEW String to a Character Array and Passing Its Pointer to a Call Library Function Node
Updated Jun 6, 2023
I want to use LabVIEW's Call Library Function Node to access a DLL function. I need to pass a string to the function, but its prototype requires a parameter defined as a pointer to a character array. How do I create the array of characters from the string and pass its pointer to the DLL?
LabVIEW strings are not null-terminated C-style strings. LabVIEW strings are similar to Pascal-style strings in the sense that the first four bytes contain the length of the string.
There are two ways to take a LabVIEW string and pass it to a DLL that is expecting a char * (pointer to character array). The most common method is to define the function parameter as a CStr. When you place a Call Library Function Node on the block diagram, double-click it to specify the prototype of the function you want to call. Here you will specify the parameter to be type String and the format to be C String Pointer. Notice how the prototype displays the data type CStr. This data type is equivalent to char *.
If you are working with string-based instrument control, it may be easier to pass an array of 8-bit integers than C strings because of the possibility of NULL values in the string. When you place a Call Library Function Node, double-click it to specify the prototype of the function you want to call. The key here is to specify the parameter type as Array and its data type as Unsigned 8-bit Integer. The dimension of the array is 1 and the format is Array Data Pointer. In LabVIEW you must convert the string to a byte array using the String to Byte Array.vi.
