To get to the
Multisim Component Search engine, from the main menu select
Place»Component»Search.
Searching by Part Number:When you are searching by part number, it is better to search by the common part number and not full manufacturer part number. For example, if you are looking for a NE555D Timer, you should search for 555
. In addition, use the asterisk (*) wildcard to give your search a wider range. If you just enter
555 in the
Component search field, only components that start with 555 will appear in the search result. But by using the asterisk and enter as shown below, you will find all parts with 555 and you won't miss the LM555 which is a good replacement for a NE555D.
Searching by Functionality:Using the example of a red LED. In the
Component Search dialog, enter Red LED in the
Function field and Multisim will search for that string in the component
Function area as shown below.
