Changing TestStand Process Model in Sequence Editor and Operator Interface
Updated Oct 22, 2024
  • TestStand
In this document, you will learn how to change the Process Model in the TestStand Sequence Editor and in the TestStand Operator Interface.
After following the steps below, you will be capable of changing the Process Model in these environments.
In the Sequence Editor:
1. Go to Configure >> Station Options:
2. Look for the Model tab
3. Select the process model you wish to switch to
In the Operator Interface:
You can confirm that the process model was successfully changed by checking the indicator at the bottom of the editor/interface:
