You can measure the circuit impedance by using the Single Frequency AC Analysis or if you want to find the impedance over a range of frequencies, you can use the AC Analysis. Multisim allows you to add expression in the analyses and the expression to find impedance is:
Z = V / IBefore you launch the analysis, place a probe on the wire where you want to calculate impedance, it will give you access to both current and voltage at the same point.
![](/servlet/rtaImage?eid=ka03q000001EH1s&feoid=00N3q00000HUsuI&refid=0EM0Z000000WApP)
The following steps are for the Single Frequency AC Analysis:
- From the main menu select Simulate»Analyses»Single Frequency AC Analysis
- Select the Output tab
- Click on the Add expression button
- Enter the expression V/I is the Expression box then click the OK button
- Select the Frequency Parameters tab
- Click on the Auto-detect button if you want Multisim to use the frequency from the schematic signal source, otherwise, enter the frequency you want
- You can select Magnitude/Phase or Real/Imaginary as the output format then click the Simulate button
- The result will display on the Grapher View
