Programmatically Change Font, Color, or Size of String Subset in LabVIEW
Updated Dec 1, 2023
  • I can manually select a portion of the text in a string control or indicator and change its colors, but how can I do this programmatically?
  • How do I programmatically change the color, font, or formatting of a section of a string control?
You can programmatically change the font of a subset of text from a string control or indicator by following these steps:
  1. Right-Click on the string control or indicator and select Create»Property Node»Text»Selection»Start
  2. Right-click on the Text.SelStart property and select Create»Constant. This specifies the offset of the first character of the selected text.
  3. Expand the property node to expose a second property.
  4. Left-click on this second property and select Text»Selection»End.
  5. Right-click on the Text.SelEnd property and select Create»Constant. This specifies the offset of the last character of the selected text.
  6. Expand the property node to expose a third property.
  7. Left-click on the third property and select Text»Font >> then the font property to be programmatically controlled.
    • For example: Select Text >> Font >> Color to bring up the Text.FontColor property on the Property Node. Right-click on the property's input node to Create Constant, then left-click on the created Color Box Constant and select a color from the palette.
  8. Repeat steps 6 and 7 to programmatically control additional font characteristics for the selected text.
Note: The Text >> Font properties (like Text.FontColor and Text.FontBold) will change the formatting for only the text selection (from SelStart to SelEnd indices). The Text >> Text properties (e.g. Text.TextColor) will change formatting for all text in the string.
The snippet below provide an example of different ways you can apply these properties.
The outcome of the code above is the following formatted string control.
