Application Usage:
- Download and run the MXIeBusDetect.exe application attached at the bottom of this article.
Note: Only use MXIeBusDetect_32bit.exe on 32-bit Windows systems, and only use MXIeBusDetect_64bit.exe on 64-bit Windows systems.
- Look for root bus devices with Bus Number Range: [0, ff] and Status: Device is running.
A full (non-limited) range of bus numbers will display as "[0, ff]". If the bus number range is not "[0, ff]", this indicates the motherboard has a limited number of buses to work with, and therefore may not be MXI-compatible.
An example of a system with limited range is shown below.
You might see phantom device status message, as shown below. These can be ignored.
- Press Enter to terminate the program.
Save Information to File
- To save this information to a file, run the executable from the command prompt, piping the information to a text file.
For example, type: MXIeBusDetect_32bit.exe > out.txt
- Press Enter to execute the command, then press Enter again to terminate the program. The information will be saved as out.txt or as your desired output filename.
MXI-Express BIOS Compatibility Software works around common BIOS limitations; however, not all possible limitations can be managed. Among the configurations that MXI-Express BIOS Compatibility Software cannot compensate for, some can be detected in advance (prior to installation of software), including:
- The presence of multiple PCI/PCI Express root bus devices, which adds complexity to the system.
 - A low maximum limit on the bus number range set by the BIOS, which limits the amount of hardware that can be attached to the system.
The installer for MXI-Express BIOS Compatibility Software checks for these issues and alerts detection through pop-up messages. In the case of multiple root bus devices, installation is prevented.
Note: MXI-Express BIOS Compatibility Software versions 1.4 and newer do support multi-root bus systems, though the MXIeBusDetect utility may suggest otherwise when run on certain systems. An alternative to detect these issues in advance is to use a stand-alone application, the MXI Express Compatibility Root Bus Detection Utility, which is attached to this article. It will provide information about the system's PCI/PCI Express root bus devices and the implications of any detected issues. You should only use the version of the MXIeBusDetect executable that corresponds to your version of Windows. 32-bit versions of Windows should use the MXIeBusDetect_32bit.exe utility, and 64-bit versions of Windows should use the MXIeBusDetect_64bit.exe utility.
