No, it is not possible set up multiple triggers on the same digitizer/oscilloscope with the NI-SCOPE driver because there is only one timing engine used by the entire module. Furthermore, the NI-SCOPE triggering functions only allow one source to be configured as a trigger. However, if multiple triggering conditions on multiple different digitizer channels are required, the
PXIe-517x reconfigurable oscilloscopes should be considered. These devices have a user accessible FPGA that allows the development of FPGA code with advanced triggering capabilities.
