You can set the Y-axis scale each channel by following the sequence below.
1. Double-click the
2D Axis System to open the 2D Axis System - Display popup as shown below.
2. In the 2D Axis System - Display popup, Click the
Curve related in Scaling session.
3. And then, Scaling is enabled in the Curve list. Click the
Scaling menu and select
Edit as shown blow.
4. If you select
Edit, the Curve-Related Scaling pop-up will appear as shown below and add
New Entry.
5. click the Mode item and select
Manual.6. You can configure the Y axis scale by setting the Begin and End values.
