To add a cursor to your XY graph, waveform graph, digital waveform graph, intensity graph, or mixed signal graph:
1. Right click on your graph
2. Go to "
Properties"
3. Select "
Cursors" from the tab and click "
add"
4.You can change the colour of the cursors and the line thickness in the pop up window, you can also allow free dragging to arrange the position of the cursors
