Adding a Cursor to a Graph in LabVIEW
Updated Nov 12, 2024
This article introduces on how to add the cursor to the XY Graph, Waveform Graph, Digital Waveform Graph, Intensity Graph, or Mixed Signal Graph.
For the simplicity, XY graph is used as an example to show how to add the cursor.
To add a cursor to the graph, follow the below steps:
  1. Right click on your graph.
  2. Go to "Properties".
  3. Select "Cursors" from the tab and click "add".
  4. You can change the colour of the cursors and the line thickness in the pop up window, you can also allow free dragging to arrange the position of the cursors.
