Download and install the following items :
MVPI-
MPManager-
MPUpdate 5.0.9To use the download center, refer to this kb :
How to Use the NI NFC Download Center ?Using MPUpdate, upload the last version of the SorbServer application in all of your device motherboard.
Follow this KB to apply the upload procedure :
Update all devices with the last firmware version. You can refer to the MP300 folder on the
download center to find your device type.
Follow this KB to apply the firmware update procedure :
How to Update the Firmware Version of My Device Using MPManager ?
In MVPi, select the production machine in the Config tab then in Option :
Click on Handler PC Parameter. In the Test Handler field, select the machine you are using. Usually, it is a Muhlbauer machine connected in TCP/IP :
Enter the correct IP adress of the machine in the Base IP adress field and select the Port used in the field Port to open. The default port is set to 10000 :
As preliminary information, you will need the IP adresses of your MP300 testers. You can have the IP adress using MPManager software (Version 3.8.2 and Later).
Under Config menu, click on the Define Couplers Configuration button :
A new window appears :
For each head (up to 128) that is going to be active during the production cycle, add a new line in this window. For each line, check the checkbox, the IP address and coupler number of the tester. If more than 32 heads are available, select the next tabs “Heads 33-64”, “Heads 65-96”, “Heads 97-128” to enter the information.
It is possible to copy the configuration of a single head, to several. Choose the parameters you want to copy, by checking or unchecking the options :
Click on OK.
Note that those settings are persistent from one session to another, which means that if you reboot the host computer MVPi runs on, the settings will remain as they were before the reboot.
Under the Config menu, click on the Define Tests & Libraries item.
It is required to have a compiled test script program (file extension: exb). You can create your own embedded application.
For each head that will be active, select the test which will be executedin the Binary file field.
The EmergencySorb.exb is the default one and is located under the MVPi installation directory.
Select the Module number and Method Id inside the executable binary file that will be executed.
If you have activated the sampling mode, you are able to select a sampling method that will be used as the alternative method in sampling mode execution. To activate the sampling mode, click on Option button in the Config menu :
In the Sampling tab, tick the Activate Test Sampling option :
