The DIAdem ANALYSIS
Resampling channel function creates a new waveform channel at a new given sample rate. The input isn't explicitly a decimation factor to get every 10th or 100th sample, but you can create the same effect with a bit of math.
- In DIAdem ANALYSIS panel, open Channel Functions function group and select Resampling function as displayed below:
- Select your X-Channel and as many Y-channels as desired. You should see a preview on the right side of the window if you are only resampling a single Y-Channel.
- DIAdem gives you the input channel's sample rate at the bottom of the window.
- Divide your Input Channel Sampling Rate [Hz] by your given decimation factor (10 for every 10th sample) to get Sampling rate of the interpolation Channel [Hz]. Here, every 10th sample at 17.1 Hz is decimated to sampling at 1.71 Hz.
- Click OK or Calculate to create a new waveform channel in your default channel group (here renamed Decimated_x10 and Decimated_x100).
- Below is a VIEW 2D Axis System with 10x decimation in purple (sampling at 1.71 Hz) and 100x decimation in blue (sampling at 0.171 Hz) verified by the channel length.
- Note: The decimated length may be different from the original length because length is an integer value.
Resampling function can be also automated in a DIAdem script by calling ChnResampleFreqBased function.
You can also refer to
Resampling shipping example .
A similar functionality can be also achieved by loading the channel to the Data Portal using
Data Reduction Navigator functionality:
- In DIAdem Navigator, right-click the channel you need to decimate
- select Data Reduction...
- check option Data Reduction and set Interval Width or No. of Intervals to the desired value
- check option 1st value to obtain a output channel with the first value of each interval of the original channel
Data Reduction can be automated in a DIAdem script by calling DataFileLoadRed command.
