How to Switch Between High Resolution and High Speed ADC Timing in LabVIEW
Updated Nov 17, 2020
  • NI-9213
  • PXIe-4353
  • NI-9207
  • LabVIEW Base
  • LabVIEW Professional
I want to select High Resolution mode for my DAQ device in LabVIEW.
We can use the DAQmx Channel Property Node to alter the Timing Mode of the ADC (In the DAQmx Channel Property: Analog Input >> General Properties >> Digitizer/ADC >> Timing Mode).
