このコンテンツは設定された言語で表示できません。
Scripting in Perl, Python and Tcl With NI Software
Updated Nov 17, 2023
  • TestStand
  • LabWindows/CVI
Programming Language
  • Python
The ability to re-use existing code while migrating to a new test software framework can save developers both time and money.  Both NI TestStand test management software and NI LabVIEW give users the ability to directly call and integrate with code written in a variety of languages such as Perl, Python and Tcl.
This article examines the basics of three of the commonly used scripting languages – Perl, Python and Tcl. This is Part 1 of a three-part series on calling scripting languages from TestStand with a focus on the needs of engineers and scientists. In this first part we will discuss the basic syntax of Perl, Python and Tcl and illustrate how to write simple scripts in these languages.
Introduction
What is a scripting language?
Scripting languages are programming languages that are typically written using high-level programming constructs, which makes them easy to learn. While there is no fixed definition of what constitutes a scripting language, some of the common distinguishing traits of these languages include:
  • Interpreted: Scripting languages are typically converted into machine-level code during runtime by an interpreter, rather than being compiled into an executable before running. While this leads to a performance hit as each line has to be interpreted on the fly, it makes for easier portability between systems.
  • Typeless: Variables can be used to hold any type of data without having to explicitly declare their type. While this can make it easy to run into typecasting errors, it makes the language easier to learn and can improve the readability of the script.
  • Native Complex Types: Most scripting languages also natively provide certain complex data types like strings, arrays, lists and hashes.
  • Garbage Collection: Most scripting languages automate garbage collection (freeing of memory used by data). This can reduce the likelihood of memory leaks occurring.
What do scripting language names mean?
Perl: Stands for Practical Extraction and Report Language
Python: Named after the BBC show “Monty Python’s Flying Circus”
Tcl: Stands for Tool Command Language
Running Scripts
Installing an Interpreter
The first step in running a script is downloading an interpreter that will take your script and convert it into machine level language.
For our tutorials and examples, we used ActiveState’s free interpreters for Perl, Python and Tcl:
Setting up the Interpreter
One of the benefits of using ActiveState’s interpreters is that the installers will automatically set up the computer’s Path environment variable so that you can call your scripts from any directory. In addition, they will also set up file associations with the file extension (.pl, .py, .tcl) with their interpreters so that you can run the script directly by calling its filename.
One caveat to be aware of is that, by default, ActiveTcl will associate .tcl files with a windows shell interpreter - wish - rather than a command line interpreter. In order to run your Tcl scripts directly from the command line, you need to modify the .tcl file association to point to the Tcl command line interpreter - tclsh.  The following direction will step you through pointing the .tcl file association to the Tcl command line interpreter.
  1. Open Windows Explorer
  2. Click Tools»Folder Options
  3. Switch to the File Types tab
  4. On the Registered file types listbox, scroll down to the extension TCL and select it
  5. The Opens with details defaults to Wish Application
  6. Click the Change button
  7. On the Opens With dialog, click Browse and select the ActiveTcl command line interpreter, tclsh
    This defaults to:
    C:\Tcl\Bin\tclsh<version_number>.exe
  8. Click the OK button on the Open With dialog
  9. Make sure that the TCL extension is now associated with Tclsh Application. Click the Apply button.
NOTE: If you use an interpreter other than ActivePerl, ActivePython and ActiveTcl, you may have to manually set up your Path environment variable to point to the interpreter’s executable. For instructions on how to do this on Windows XP, refer to Microsoft KnowledgeBase 310519: How To Manage Environment Variables in Windows XP.
Executing a Script
The typical syntax for running a script from the command line is:
<interpreter.exe> <script_filename > <command_line_arguments>
However, since we already associated the script file extensions with the interpreters, we can also directly run the script from the command line using:
<script_filename> <command_line_arguments>
To make sure that your interpreter installed properly, you can try to run the following scripts from the command line. The downloadable files are located attached to the bottom of this article.
  • Perl:
    Open hello_world.pl
    Run using: perl.exe HelloWorld.pl
  • Python:
    Open hello_world.py
    Run using: python.exe HelloWorld.py
  • Tcl:
    Open hello_world.tcl
    Run using: tclsh<version_number>.exe HelloWorld.tcl
Editing Scripts
While you can edit a script file in any text editor like notepad, or any text based Development Environment like LabWindows/CVI or Microsoft Visual Studio, we wrote our examples in ActiveState’s free Integrated Development Environment, Komodo Edit (version 5.0). We chose Komodo Edit because it’s built in features (autocomplete, calltips, syntax coloring and checking) support these three scripting languages amongst others.
Basic Syntax
The following section walks you through the basic syntax used in Perl, Python and Tcl. You can download the entire sample at the bottom of this article.
Declaring and Using Scalar Variables
Perl
#Create a numeric variable
my $myNumber = 5;
#Create a string
my $myString = "Hello World";
#Create a new numeric and assign the original to it
my $myNewNumber = $myNumber;
Python
myNumber = 5;
#Create a string
myNewNumber = myNumber;
Tcl
set myNumber 5;
#Create a string
set myString "Hello World";
set myNewNumber $myNumber;
Displaying output to the Standard Output (STDOUT)
Perl
#Print a string to the screen
print "Hello World\n";
#Print a string and a number
my $sum = 5;
print "The sum is: ", $sum, "\n\n";
Python
print "Hello World";
sum = 5;
print "The sum is: ", sum, "\n";
Tcl
puts "Hello World";
set sum 5;
puts "The sum is: $sum \n";
Declaring and Using Lists
Perl
#Declare a list with three elements
my @myList = (5, "foo", 3.14);
#The index of the last element is accessed by $#<listname>
print "Size of myList: ", $#myList + 1, "\n";
#Access a single element in the list
print "The second element in the list is: ", $myList[1], "\n\n";
Python
myList = [5, "foo", 3.14];
#The length of the list is accessed by len(<listname>)
print "Size of myList: ", len(myList);
print "The second element in the list is: ", myList[1], "\n";
Tcl
set myList {5 "foo" 3.14};
#The index of the last element is accessed by llength
puts "Size of myList: [llength $myList]";
puts "The second element in the list is: [lindex $myList 1] \n";
Reading User Input from the Command Line (Command Line Arguments)
Perl
#Command line arguments are stored in list ARGV
#Get number of arguments
print "Number of Command Line Arguments: ", $#ARGV + 1, "\n";
#Access individual argument
print "The first Command Line Argument is: ", $ARGV[0], "\n\n";
Python
import sys;
#Command line arguments are stored in list sys.argv
print "Number of Command Line Arguments: ", len(sys.argv) - 1;
print "The first Command Line Argument is: ", sys.argv[1], "\n";
Tcl
#Command line arguments are stored in list $argv and $argc
puts "Number of Command Line Arguments: $argc";
puts "The first Command Line Argument is: [lindex $argv 0] \n";
Reading User Input from the Standard Input (STDIN)
Perl
#Read a user input from the keyboard (terminates on return key)
print "Enter value, and then press Enter: ";
my $myUserInput = <STDIN>;
Python
myUserInput = raw_input("Enter value, and then press Enter: ");
Tcl
puts "Enter value, and then press Enter: ";
gets stdin myUserInput;
Syntax of Common Conditional Statements
Perl
#if, elseif, else
if ($myNumber == 5)
    print "My Number is Five \n";
elsif ($myNumber == 3.14)
    print "My Number is Pi \n";
else
    print "My Number is neither Five nor Pi \n\n"
#while loop
while ($myNumber != 0) #could do: until ($myNumber == 0)
    print "My Number is: ", $myNumber, "\n";
    $myNumber -= 1;
print "\n";
#for loop
for ($myNumber = 0; $myNumber < 5; $myNumber++)
print "\n";
#foreach loop
foreach my $currentElement (@myList)
    print "The current element is: ", $currentElement, "\n";
Python
#if, elseif, else
if (myNumber == 5):
    print "My Number is Five";
elif (myNumber == 3.14):
    print "My Number is Pi";
else:
    print "My Number is neither Five nor Pi \n";
#while loop
while (myNumber != 0):
    print "My Number is: ", myNumber;
    myNumber -= 1;
print "\n";
#for loop
for myNumber in range (0, 5):
print "\n";
#foreach loop
for currentElement in myList:
    print "The current element is: ", currentElement;
Tcl
#if, elseif, else
if {$myNumber == 5} {
    puts "My Number is Five \n";
} elseif {$myNumber == 3.14} {
    puts "My Number is Pi \n";
} else {
    puts "My Number is neither Five nor Pi \n\n";
#while loop
while {$myNumber != 0} {
    puts "My Number is: $myNumber";
    incr myNumber -1;
puts "\n";
#for loop
for {set myNumber 0} {$myNumber < 5} {incr myNumber} {
puts "\n";
#foreach loop
foreach currentElement $myList {
    puts "The current element is: $currentElement";
Next Steps
Now that we have looked at the basics of these three scripting languages, we are ready to proceed to
