Getting Started with VLM: Managing Client Permissions
Updated Jun 1, 2026
  • Volume License Manager
This article is part of the Getting Started with VLM series. This is a brief guide on how to provide users with license permissions.
This article will explain how to distribute permissions for your users as a Software Administrator. You'll learn how to allow users to access the software either by their user or computer (depending on your license type). It will also explain how to check out or return a license.
Introduction
  • To add, modify or remove permissions for your clients to access software on your Volume License Agreement (VLA), you must first determine whether you have named-user license, computer-based license or a combination of both. You may check the "Licenses" tab on the bottom left corner to identify your license type(s).
  • For a named-user license, you will need the login name of the user you want to grant permissions to. This is the name used to log onto the machine. For more information on client management,please see this section of the User Manual.
  • For a computer-based license, you will need the client computer name. You may retrieve the Computer Name through the License Manager tool on the client's machine. The Computer Name is located on the Computer Information tab.
With this information, you can start by adding the user/computer to your Volume License Server and get ready to assign permissions based on the model of your licenses.
For VLM 3.0 or later
Below you'll find examples on how to add a computer/user to your license server. For computers, position yourself under the Computers tab at the bottom left and select the Add Computer option:
For users, position yourself under the Users tab at the bottom left and select the Add User option:
Modifying License Permission(s):
+ Adding Computer/User:
After entering the Computer/User name and completing the Computer/User Information fields, you can assign a license by selecting the Add button in the Explicit Licenses window.
      + Creating Computer/User groups:
      Alternatively, if you have already created a License Group for multiple computers or users, you may add the computer as a member of that group instead.
      + Removing Computer/User:
      To remove a computer, go to the Computers tab at the bottom left. Select the appropriate user, then choose the Delete Computer option to complete the removal.
      To remove a user, go to the User tab at the bottom left. Select the appropriate user, then choose the Delete User option to complete the removal.
      After adding the Computer/User Client and provisioning them with a license, make sure to click the Apply Changes button (located in the top-left corner) to save the latest updates. If the client computer has already established communication with the server prior to license provisioning, the next step is simply to launch the software on the client side. If the client has not yet connected to the server, please refer to the link provided above for further instructions.
      If you are moving servers from one previously managed by VLM 3.0 or later, you can import configurations for your users and computers by using NI Volume License Manager Import Utility. Please refer to Using the VLM Import Utility for instructions.
      For VLM 2.1.1 and earlier
      Once you have obtained the required computer/user information, launch VLM, and follow these steps:
      1. Click the Add Computer or Add User button. Enter the client information in the subsequent dialog box. (The fields in the owner section of the information tab are optional and can be used for your own record keeping).
      2. Select the Permissions tab, which lists available software packages included in your VLA.
      3. Place checkmarks next to each software package that the client will need to use.
      4. If a computer-based license, add all users connected to the computer by selecting the Users tab. Click OK, and repeat this process for each client computer.
      5. Click Apply Changes to refresh the server with these new settings and permissions. Failure to apply the changes will result in the changes being lost.
      Adding Permissions to the Software License:
      You can also use the VLM Import Utility to help you import the client configurations from a prior server. To learn how to do this, refer to Volume License Manager Import Utility.
      Note: If your client computer or user will not be connected to the VLM server through the network, you will need to create a disconnected license.
