Disconnect any additional instruments, such as an oscilloscope, from the digital lines between the PXI ARINC 429 module and the third‑party device.
Connecting instruments in parallel can interfere with ARINC 429 communication for the following reasons:
- A faulty input channel on the external instrument
- Incorrect grounding between the instrument and the ARINC 429 hardware
- Signal loading effects that distort digital levels
After disconnecting all parallel instruments, run the LabVIEW example again and verify whether data transmission and reception are restored.
If the issue persists, contact NI Technical Support for further troubleshooting.
