Interactively Configuring an EPICS Server I/O Server
Open and save a new LabVIEW project
Add two virtual folders to the project
Right click My Computer and select New » Virtual Folder
Name one folder Client and the other Server
Add a library into each folder
Right click Client and select New » Library
Right click Server and select New » Library
Respectively title the libraries Client Library and Server Library
The project should now look similar to Figure 1
Figure 1: Preparing the LabVIEW Project
- Create the Shared Variables listed in Table 1
Right click Server Library.lvlib and select New » Variable
Under the Variable tab, apply the parameters specified in Table 1
The Shared Variable Properties window should look similar to Figure 2
Name
Variable Type
Data Type
Amplitude
Network-Published
Double
Frequency
Network-Published
Double
Table 1: Server Shared Variables
Figure 2: Shared Variable Properties Window
- Add a new I/O Server to the Server Library
Right click Server Library.lvlib and select New » I/O Server
Select EPICS Server » Continue... and the window in Figure 3 will appear
Figure 3: Configuring an EPICS Server I/O Server
- Add the shared variables created in Step 4 to the I/O Server
Select Add/Remove Variables...
Browse to Server Library.lvlib and select the two variables
Select Add >> to add the variables to the I/O Server
The configuration window should look similar to Figure 4
Select OK
Figure 4: Adding New Variables to an EPICS Server I/O Server
- Note the EPICS Process Variables (PVs) have been created for both shared variables
At this time, take note of the Process Variable names, they will be needed in a later step
The window will look similar to Figure 5, however PV names and paths will be different
Select OK
Figure 5: Newly Created EPICS Process Variables
Building an EPICS Server VI
The server VI in this tutorial will publish amplitude and frequency parameters to the EPICS network. These parameters will be read by a client and then fed into a function generator.
For more information on the differences between EPICS Servers and EPICS Clients, see the Developer Zone Article, Introduction to EPICS or the Argonne National Laboratory website.
Add a new VI to the Server virtual folder
Right click Server and select New » VI
Save the VI as EPICS Server.vi
- Build a front panel similar to that shown in Figure 6
Add two numeric controls (preferably knobs)
Add a boolean stop control
Figure 6: EPICS Server VI Front Panel
- Build the block diagram shown in Figure 7
Add a While Loop and wire the Stop Button to the conditional terminal of the loop
Add the Amplitude and Frequency Shared Variables to the block diagram
Right click on the variables and select Access Mode » Write
Wire the Amplitude and Frequency controls to the corresponding shared variables
Add a 100 ms Wait to the loop to give the processor time for other tasks
Figure 7: EPICS Server VI Block Diagram
Interactively Configuring an EPICS Client I/O Server
Add a new I/O Server to Client Library
Right click Client Library.lvlib and select New » I/O Server
Select EPICS Client » Continue...
The "Configure EPICS Client I/O Server" window will appear
- Add new records to the I/O Server
Click the Add Records button twice to add two new records in the PV List
Replace the default PV names with the names generated by the Server I/O Server
Change the data types of both Process Variables to Double
The window should now resemble Figure 8, select OK
Figure 8: Configuring the EPICS Client I/O Server
- Create corresponding Client Bound Shared Variables
Right click EPICS Client1 and select Create Bound Variables...
The "Create Bound Variables" window will appear, browse to Client Library.lvlib
Under EPICS Client1, select the VAL fields for both variables
Click the Add >> button to move the fields to the Added Variables list
The window should now resemble Figure 9, select OK
Figure 9: Creating Bound Shared Variables on the EPICS Client
- Rename the bound variables
After completing step 2, the "Multiple Variable Editor" window will appear
It may be desirable to change the names of the variables to something more meaningful
Change the variable names by double clicking in the Name field and typing the new name
The window should now look similar to Figure 10, select Done
Figure 10: Changing Variable Names With the Multiple Variable Editor
Building an EPICS Client VI
- Add a new VI to the Client virtual folder
Right click Client and select New » VI
Save the VI as EPICS Client.vi
- Build a front panel similar to that of Figure 11
Add a waveform chart
Figure 11: EPICS Client VI Front Panel
- Build the block diagram show in Figure 12
Add the ClientAmplitude and ClientFrequency shared variables to the block diagram
Add a Basic Function Generator to the block diagram
Wire the ClientFrequency shared variable to the frequency input of the function generator
Wire the ClientAmplitude shared variable to the amplitude input of the function generator
Wire the Signal Out terminal of the Basic Function Generator to the waveform chart
Figure 12: EPICS Client VI Block Diagram
Examining Flow of Communication
Run Server.vi, notice that Server Library.lvlib is automatically deployed
Run Client.vi, notice that Client Library.lvlib is automatically deployed
Make changes to the controls on the Server front panel, the client will update accordingly
See Figure 13 for a view of the front panels side by side
Figure 13: Server & Client Front Panels Running Simultaneously
- Open Distributed System Manager (DSM)
Select Tools » Distributed System Manager from the top menu of either VI
Browse to Localhost then select Client Library and Server Library to expand
The network published shared variables and process variables can now be viewed
Multiple items can be viewed simultaneously by holding Ctrl during selection
See Figure 14 for a view of DSM that shows all values being updated
Figure 14: Viewing Flow of Communication in Distributed System Manger
Figure 14 shows the flow of communication as data passes between the EPICS Server and EPICS Client. The four steps in this process for each element are as follows:
LabVIEW Server VI writes to shared variables hosted on the server
EPICS Server I/O server updates values from shared variables to EPICS process variables
EPICS Client I/O Server reads values from EPICS process variables and writes to shared variables
LabVIEW Client VI reads from shared variables hosted on client
