Getting Started with NI VLM: Configuring Server Settings
Updated Jul 8, 2024
  • Volume License Manager
  • NI License Manager
This article will explain how to configure server settings in NI Volume License Manager (VLM). This information could be helpful if you need to see which ports are being used, if you would like to change ports or ensure they are open. It can also help if you are having trouble accessing the volume license server, if communication is slow or sluggish, or if you are getting various errors.
This article is part of the Getting Started with VLM series.
There are several items below to consider when configuring your server settings. If you encounter problems communicating with your volume license server, please review the VLM Troubleshooting Guide.
Automatically send VLA log to NI
Enable this setting to automatically send VLA log to NI at the end of every quarter.
For VLM 3.1 or later
  1. Select the Tools» Preferences menu item.
  2. Select the General tab.
  3. Under Miscellaneous Settings, you have the option to Automatically send VLA Log to NI.​
                                                    Enable VLM log
        NI VLM 3.3 Preferences - Automatically send VLA Log to NI
Configure NI VLM Ports
Change or unblock the ports on the server that hosts your National Instruments licenses and on end-user computers if you are running other license servers on this computer or if you have a firewall enabled.
  1. Configuring NI VLM Ports
  2. Optionally, also review Configuring Communication Ports for NI VLM or FLEXnet Publisher
NI VLM 3.0 & 3.1 Preferences - Main Licensing Port
For VLM 2.1.1 and earlier
  1. Select the Options»Preferences menu item.
  3. Enter the port you want to use in the License Server Port option. The default port number is 27000. Ports range from 1-64000, inclusive.
  4. Enter the port you want to use in the Background Process Port option. This port does not need to be changed unless you have a conflict or a firewall on the license server. The default port number is randomly selected by the license server and ranges from 1-64000, inclusive.
NI VLM 2.1.1 Preferences - Main Licensing Port
Enable the Usage Log
Enable or disable the usage log. The usage log contains usage information of NI VLM-controlled software, such as check-in and check-out events, along with relevant client information.
  1. Select the Reports tab and choose the type of report you'd like to generate.
NI VLM 3.1 Reports Tab
For VLM 3.0
  1. Select the Tools»Preferences menu item.
  3. Under Miscellaneous Settings, you have the option to Enable Usage Log. By default, this is enabled.
NI VLM 3.0 Preferences - Usage Log
  3. Select the Enable Usage Log checkbox. (It will be disabled if the license file is expired.)
NI VLM 2.1.1 Preferences - Usage Log
Set Administrator Information
Enter administrator information, including name, phone, email, and URL. This information is included in any installers you create with the Create Volume License Installer wizard. The email address you specify here is used when you email disconnected licenses to end users.
For VLM 3.0 or later
  1. Setting the Administrator Information
NI VLM 3.0 & 3.1 Preferences - Administrator Information
  2. Select the Administrator tab.
  3. Complete the Name, Phone, Email, and URL fields.
NI VLM 2.1.1 Preferences - Administrator Information
Set Overdraft Policies
Enable the ability to add new licenses to your Volume License Agreement (VLA).
  1. Configuring Overdraft
  2. Setting Overdraft Policies
NI VLM 3.0 & 3.1 Preferences - Overdraft
  2. Select the Policies tab.
  3. Check Allow Overdraft if you want to allow overdraft. This setting applies to all products in your license file, except when specified. Note: This setting does not apply to products in your volume license agreement that use concurrent licenses.
  4. Check Enable Pay-As-You-Go if you want to enable pay-as-you-go. This setting reminds you when you overdraft to send an email to services@ni.com  in order to cover the overdraft by purchasing the corresponding licenses.
NI VLM 2.1.1 Preferences - Overdraft
Enable Technical Support for End Users
Check this box to add end-user information to the Activity Compliance Log. Only end users included in the Activity Compliance Log are eligible to contact NI for technical support.
This setting is automatically enabled.
For VLM 3.0
  3. Under Miscellaneous Settings, ensure that Include client information in the activity compliance log is checked.
NI VLM 3.0 Preferences - Miscellaneous Settings
  3. Ensure that Include Owner Information in Activity Compliance Log for Technical Support is checked.
NI VLM 2.1.1 Preferences - Policies
Configure Custom Fields
Configure custom fields to store information about end users and computers.
  1. Configuring Custom Fields
NI VLM 3.0 & 3.1 Preferences - Custom Fields
  2. Select the Custom Fields tab.
  3. Add, Delete, or Rename fields as desired.
  4. Highlight any field and click Require to select whether the field is required or optional.
  5. Note: All fields are optional when you add a computer or user from within NI VLM, regardless of this setting.
NI VLM 2.1.1 Preferences - Custom Fields
Configure Email Server Settings
Enable the ability to email disconnected license files from within NI VLM through an SMTP server on which you have an account.
For VLM 3.1
  1. Configuring Email Server Settings
NI VLM 3.1 Preferences - Email Server
For VLM 3.0
  2. Select the Email Server tab.
  3. Enter the SMTP server address in the Outgoing Mail Server Information box. You can optionally specify a port number, for example, smtp.example.com:465. If your SMTP server requires SSL encryption, check This server requires an encrypted connection (SSL). The default port is 25 if you are not using SSL encryption. If you are using SSL encryption, the default port is 465.
  4. If the SMTP server requires authentication, enter in the Login Information box the user name and password you use on your SMTP server.
  5. If you want to receive a copy of every email sent from within NI VLM, check Carbon copy the administrator on every email sent by NI VLM in the Options section.
NI VLM 3.0 Preferences - Email Server
  5. If you want to receive a copy of every email sent from within NI VLM, check Copy the administrator on every email sent by NI VLM in the Options section.
NI VLM 2.1.1 Preferences - Email Server
Next Steps
Next Step: Adding Client Permissions
Previous Step: Installing the License File
