Resetting the NI USRP-29xx's IP Address to Default
Updated Oct 21, 2021
  • USRP-2920
  • USRP-2921
  • USRP-2922
  • USRP-2940
  • USRP-2942
  • USRP-2943
  • USRP-2944
  • USRP-2945
The IP address of the NI USRP-29xx does not change in the NI USRP Configuration Utility. How can I reset the device's IP address to its default value?
If the NI USRP-29xx device cannot be found in the NI-USRP Configuration Utility or the IP address cannot be set, you must reconnect power to the device to enter the safe (read-only) image. Doing this will reset the device's IP to the default value of 192.168.10.2. For a step-by-step guide, see Why Doesn't the Device IP Address Reset to the Default? in the NI USRP 2920/2921/2922 Getting Started Guide . See section.
