Create a Database Group
Ultiboard and Multisim both share a common database structure which organizes the various components into logical groups. The creation task therefore begins in the Ultiboard Database Manager.
- Select Tools >> Database >> Database Manager to display the Database Manager (Figure 1).
Figure 1 - Database Manager
- In the Database Manager select the User Database (the red square in Figure 1 above).
Custom groups can be created in the Database Manager to logically organize where to save the footprint. The database group does not have to be created for every new component. The groups are created to assist in organizing the database appropriately. If a group has already been created which your custom component can be saved to, you can skip directly to e.
- Select the New Database Group icon (the yellow square in Figure 1 above).
- A new branch will appear to signify a group in the User Database root. Enter the group name, Custom SMD.
- Select the Create New Part icon (the blue square in Figure 1 above). NI Ultiboard will display a dialog box displaying the options of the type of component to create as displayed in Figure 2.
Figure 2 - Select Part
- Select the PCB Part option in the dialog box shown in Figure 2.
The Ultiboard design area will now be in the ‘Footprint edit mode’ and display the x?? symbol (Figure 3). x? represents the Reference Designator (RefDes) and ? represents the Value of the component. These values will be edited later in the design process in Step 4.
Figure 3 - Footprint Edit Mode
Edit the Grid Spacing
It is important to begin the design process by setting the units of measurements for the landpattern design grid. When placing components, the design grid is what objects will snap to when they are being moved and/or placed. The grid spacing therefore defines the degree of precision with which objects can be placed in the work-area.
- Select Options >> PCB Properties.
- Click on the Grid & Units tab.
Figure 4 - Grid Properties
- In the units section (Figure 4) set the Design Units as mil.
- To set the various Ultiboard design grids select Component Grid in the Grid Step Name combo box (the red box in Figure 4).
- Set the Grid Step Value to 1 mil
- Select the Copper Grid in the Grid Step Name combo box.
With these settings both components and copper will be placed on a 1 mil by 1 mil design grid.
Placing Landpattern Pins
Both THT (through-hole technology) pins and SMD (surface mount device) pads can be placed onto a custom landpattern. The following steps will outline how to add an array of SMD pads.
- Select Place >> Pins. This will display the Place Pins dialog box (Figure 5).
Figure 5 - Pin Properties Dialog
You will now define a 10 by 2 array of SMD pins for our custom landpattern.
- Select the SMD Pin radio button. The following values, such as Top, Pin Length, Pin Width and Pin Radius define the shape and physical dimension of the each pin. Set the following values in Table 1 to define the pin properties (as in Figure 6);
Table 1: Pin Dimensions
Field Name
Value
Field Description
Top
Rounded Rectangle
The top field described the shape of the pad. Other options include Round, Rectangle etc…
Pin Length
58.34
The pin length defines the vertical dimension of the pin
Pin Width
15
The pin width defines the horizontal dimension of the pin
Pin Radius
7.5
In the case of rounded objects, the pin radius defines the radius of the circular part of the object
Figure 6 - Set SMD Pin Properties
- You will now create the 10 by 2 SMD pin array to place on the landpattern. The vertical and horizontal spacing that will now be set indicate the center-to-center distance between adjacent pins. Set the following spacing values in Table 2. The dialog box should look like Figure 7.
- Click on the OK button to place the pads onto the landpattern
Table 2: Pin Spacing
Field Name
Value
Field Description
Vertical
25
The center-to-center vertical spacing between adjacent pins.
Horizontal
200
The center-to-center horizontal spacing between adjacent pins.
Rows
10
The number of rows in the pin array
Columns
2
The number of columns in the pin array
Note: The above dialog settings can be changed to fit your specific landpattern. For example, if both Rows and Columns are set to 1, you can place individual pins.
Figure 7 - Set SMD Pin Spacing
Pin 1 of the pin array is the upper-left pad and is attached to the mouse cursor. To accurately place the pad so that the reference point is in the middle of the pad press the asterisk key (*) on the right number pad (not shift + 8). Laptop users must press FN + 0.
The Ultiboard work area will now appear as in Figure 8. You will notice that our pins are oriented incorrectly (vertically, rather than horizontally) and must be rotated by 90 degrees.
Figure 8 - Pin Setup
- In the Select toolbar, click the Enable Selecting SMD pads icon as shown in Figure 9.
Figure 9 - Select Toolbox (SMD Pads)
- Drag the mouse across the design area to create a selection box, which selects all of the SMD pins
- Double-click on one of the selected pins. The SMT Pin Properties dialog box will appear. Select the General tab.
- Set the Rotation value to 90 degrees (as in the red box in Figure 10). Click on the OK button to save the change. You will notice that the SMD pins have been rotated and now look like Figure 11
Figure 10 - Pin Angle
Figure 11 - Final SMD Pin Orientation
Changing Pin Names and Values
During the creation of a new landpattern pins may be placed onto the design in a random order. It may therefore become necessary to edit the value associated with each pin so that they are numbered sequentially around a package.
- Double-click on the pin in the bottom right-hand corner. The SMT Pin Properties dialog will appear. Select the Attributes tab.
- The attribute list (Figure 12) displays the tag which stores the pin number (NUMBER), the pin value (20) and its visibility (None).
- Select the NUMBER tag in the attribute list, which will activate the Change button (red box in Figure 12). Click the Change button.
Figure 12 - SMD Pin Properties
- In the attribute dialog box, changing the Value field (red box in Figure 13) will change the value of the pin.
Figure 13 - SMD Pin Attributes
In general a package such as this has the pins numbered sequentially in a counter-clockwise direction. Therefore pin 10 should be in the bottom left-hand corner and pin 11 in the bottom right-hand corner. The final pin number configuration for this design should be as in Figure 14. Therefore to change the pin number;
- Change the Value field to 11 and click on the OK button. Click on the OK button in the SMT Pin Properties dialog box to save the changes.
- Repeat 4., 5. and 6. for all the pins for the required configuration (as in Figure 14).
Figure 14 - Component Pin Setup Map
Setting Reference ID and Value location
In Figure 11 you will continue to notice the x?? symbol, which represents the Reference Designator and Value of the landpattern.
The Reference Designator is the key identifier of the component and is represented as x?. This x can be changed so that it corresponds with the type of component it is associated with. For example, if this landpattern was for a resistor this value could be set to R. The ? represents a number to denote the different components in a design. So, returning to the example of a resistor, the resistors placed onto a design, would be named R1, R2, R3 etc…
Value, represented by the ? symbol, is the physical value of the component. Taking the example of the resistor into consideration once more, the ? could equal 20k for 20 Kohms.
In this step you will select, move and alter the RefDes and value.
- In the Select toolbox, click the Enable Selecting Attributes icon as shown in Figure 15 (in the red box). This will allow you to refine the selection of components on the landpattern to be only the RefDes and Value attributes.
Figure 15 - Select Toolbox (Selecting Attributes)
The RefDes and Value are currently overlapping the landpattern placement as shown in Figure 11.
- Click on the X? symbol and place it to the upper-right of the pad array.
- Click on the ? symbol and place it to the upper-right of the pad array.
- Double click on X? and select the Attribute tab
- In the Value field set the REFDES tag to U? as in Figure 16 (in the red box)
- Click on OK to apply changes.
Figure 16 - REFDES Attribute Properties
When the custom component is now placed the RefDes for the landpattern will be U1, U2, U3 etc…
Generally the Value attribute, ?, is set to either visible or invisible depending on the need to highlight the value of the landpattern on the final design. In this example, it will be set to invisible.
- In the Visibility section of the attributes set the Invisible radio button
Using the Ruler Bar
Both along the top and left side of the Ultiboard design area are the ruler bars in Figure 11. If the ruler bars cannot be seen, go to View >> Ruler Bars. These ruler bars allow the positioning of dashed lines to align shapes from one object to the next, precisely within the design area. For the following steps refer to Figure 14 for the pin numbers.
- Left-click in the horizontal (top) ruler bar area for a small arrow marker to appear and move the marker immediately to the right of pin 1 (Figure 17).
- Left-click to place a marker, 5 mils to the right of the marker placed in a. You will notice that the distance between two markers is displayed in the ruler bar (Figure 17)
- On the vertical (left) ruler bar place another marker directly above pin 1 (Figure 17)
- Repeat 1., 2. and 3. to align ruler bar markers at the right and bottom of the SMD pad arrays as shown in Figure 17.
Figure 17 - The Ruler Bar
These markers will now act as a guide on where to begin the placement of the landpattern shape on the silkscreen layer in step 7.
If at any time markers need to be cleared, you can right-click on a specific marker and select Clear, or select Clear All to remove all markers.
Place the Landpattern Shape on the Silkscreen
The placement of shapes on the silkscreen layer defines how the custom component will appear in your design. It represents the physical dimensions of the package. In this step you will utilize the ruler markers set up in step 4 to place a rectangular landpattern shape.
- In the Design Toolbox (Figure 18) double-click on the Silkscreen Top to make that particular layer active. This will highlight the layer in a red.
Figure 18 - Design Toolbox
- Select Place >> Graphics >> Rectangle.
- Ultiboard, now in a drawing mode is prepared to draw a rectangle. Line up the mouse to the upper left hand point (5 mils from pin 1 as indicated by the ruler markers in Figure 16).
- Left-click and drag the mouse, drawing a rectangular shape within the inner rectangle of Figure 11.
- The rectangle will appear as a solid, filled-in shape. Click on the Enable selecting Other Objects icon in the Select toolbar (Figure 19) and double-click on the solid rectangle.
Figure 19 - Select Toolbox (Select Other Objects)
- In the Rectangular Properties dialog, select the General tab. In the Area section, click on the Style button to change the black rectangle to a rectangular outline as in Figure 20 (red box). Click on the OK button.
Figure 20 - Rectangle Properties
The landpattern will now appear as shown in Figure 21.
Figure 21 - Final Landpattern
Creating a 3D Landpattern
In Ultiboard a design can be previewed in 3D to virtually represent the final design. In order to setup the custom landpattern for this 3D preview, the necessary information should be setup at the creation stage.
- In the Design Toolbox (Figure 18) double-click on the Silkscreen Top to make that layer active. This will highlight the layer in a red.
- Click on the Enable selecting Other Objects icon in the Select toolbar (Figure 19) and right-click on the rectangle package shape. Select Copy in the pop-up menu.
- Select Edit >> Paste and place the ghosted image onto the Ultiboard work area to the right of the landpattern.
- Double click on the copied rectangle and select the Position tab in the Rectangle Properties dialog box.
- In the Layer combo box select the 3D-Info Top option as shown in Figure 22. Click on OK.
Figure 22 - 3D Rectangle Properties
- You may notice that the copied 3D box has now disappeared as it becomes associated with the 3D layer, which is not currently an active layer. To view the rectangle again, double-click on the 3D-InfoTop layer in the Design Toolbox to make it active. The 3D rectangle will appear in red.
- Select the 3D info rectangle and move it so it is positioned directly on top of the original silkscreen shape.
- Double click the black work-area and select the tab for 3D Data.
- Set the properties for the 3D information (Table 3) and the dialog will appear as in Figure 23 (in the red box). Click the OK button.
Table 3: 3D Information
Field Name
Value
Field Description
Enable 3D for this object
Checked
Enables Ultiboard to render a 3D object
Height
45.27555
The height in mils of the 3D object
Offset
1.96850
The offset height from board
Use 2D data to create 3D shape
Checked
Uses the 2D shape on the silkscreen layer to create the package shape
Solid Shape
Selected
Creates a solid 3D representation
Figure 23 - 3D Settings
- From the 3D Data tab select the Pins section
- Set the properties for the 3D Pin information as in Table 4. Click on the OK button.
Table 4: 3D Pins
Field Name
Value
Field Description
Angle to Pad
90
Sets the angle at which Ultiboard will render the pin connections with respect to the package.
Pin Shape
Checked
Defines the shape of the 3D pin
Type
SMDPIN
Renders the specific type of pin
In the 3D Preview you should immediately notice that the pins on the left side of the component face away from the package. This is because by default, the leads on a horizontal SMD pin will be directed towards the left. Therefore the pins must be re-orientated towards the package by rotating them 180 degrees.
- Hold down the CTRL key and select the right column of pins on the landpattern
- Double-click on one of the selected pads.
- In the SMT Pin Properties dialog box select the General tab
Recall, in step 3 that the pins were set to 90 degrees for a horizontal orientation.
Due to this 90 degree rotation, we must rotate an additional 180 degrees, in the above step so that the 3D leads are now directed towards the component. 90 + 180 = 270 degrees.
- Set the Rotation angle to 270.
- Click on the OK button.
If you double click in the black work-area and select the tab for 3D data you will notice that as in Figure 24, the pins are properly positioned with respect to the 3D package.
Figure 24 - 3D Pin Settings
Saving the Landpattern
With the landpattern created all that remains is saving the to the Ultiboard database.
- Select File >> Save to Database.
- In the database section select the Custom SMD group created in step 1 (Blue box in Figure 25).
- Name the component SMD20 as in Figure 20 (red box).
Figure 25 - Save Dialog Box
Adding the Landpattern to a Multisim Database
Before a custom landpattern can be utilized in Multisim, it must be added to the database. Once added to the database, it can be seen as an available landpattern, or footprint, and added to a component.
In this step, the SMD20 tutorial landpattern created will be associated with the symbol created in Part 1 of the tutorial.
- Open NI Multisim.
- Select Tools >> Database >> Database Manager.
- In the Database Manager select the Components tab. Under the Database Name, select the User Database.
- In the Component List select the THS7001 component and click on the Edit button.
- In the Component Properties dialog box click on the Package tab.
- Click on the Add from Database button.
- In the Select Package dialog box select the User Database (red box in Figure 22). You will notice that currently the User Database does not see the landpattern that has been created in Steps 1 to 9 of this tutorial.
- To add the landpattern click on the Add button (blue box in Figure 26).
Figure 26 - Multisim Database Manager
- In the Add a Footprint dialog box set the following data as shown Table 5. The dialog box will appear as in Figure 27 (red box);
Table 5: Add a Footprint
Field Name
Value
Field Description
Database Name
User Database
The database in which you saved the landpattern in Ultiboard
Manufacturer
Generic
An additional manufacturer identifier
Package
SMD20
This is a CASE SENSITIVE field, and must identify the landpattern exactly as it is saved in Ultiboard
Ultiboard Footprint
SMD20
This is a CASE SENSITIVE field. While the Footprint field identifies the specific package name of the component it can be associated with the Ultiboard Footprint so that a generic footprint with the same dimensions can be transferred to layout
Number of Pins
20
Number of pins on the landpattern
SMT/TH
Surface Mount
The type of pin technology Surface Mount or Through Hole
Figure 27 - Add a Package
- You will notice that the SMD20 can now be previewed within the dialog box. Click on the Select button to select the newly added SMD.
- Click on the OK button to save the component settings.
- Save the component to the appropriate database and group (as it was originally saved to) and click on the OK button. You will be prompted to overwrite the original component. Choose the Yes button.
Success!! You have created a custom Ultiboard landpattern, defined a 3D model and associated it to a Multisim symbol.
