Go to the folder C:\ProgramData\National Instruments\Volume License Manager on your computer. Keep in mind that ProgramData is a hidden folder.
Delete the following three files:
- nilm.opt
- nivlm.dat
- nivlm.lic
Please note that beginning with 2023 Q1 version, NI VLM uses an SQLite database instead of SQL CE. As a result, the database file is now named nivlm.sqlite.dat. In this case, please ensure that you delete this file as well.
