该内容不适用于您选择的语言
Import .m Files to LabVIEW With the MathScript Node
Updated Sep 5, 2023
  • LabVIEW 2017 MathScript Module
How can I use my .m scripts that I have written previously in LabVIEW MathScript Node?
Note: NI does not recommend LabVIEW MathScript Module functions for new designs. Refer to www.ni.com/migratemathscript for information and recommended alternatives.
The Mathscript Node reads the .m files from a configured search path. This can be found using the following method:
  1.  Open LabVIEW MathScript Window:
  • Navigate to Tools>> Mathscript Window
  1. Open LabVIEW MathScript Properties from LabVIEW MathScript Window:
  • File >> LabVIEW MathScript Properties
  1. Select MathScript: Search Paths
  • ​​​​This will be found the left Category Pane
  • Once selected the right pane will show you the search path(s) that LabVIEW looks for .m files.
In order to use your mathscript .m files in the MathScript Node you can simply add your .m files to the file location specified by the Search Path.
