Install WebDAV and SSL Support on Your Target
NI Linux Real-Time
You do not need to complete any steps to install WebDAV and SSL support. These components are enabled by default on NI Linux Real-Time targets.
ETS and VxWorks
Complete the following steps to install WebDAV and SSL support on ETS and VxWorks targets.
1. Open
NI Measurement and Automation Explorer (NI MAX).
2. Expand
Remote Systems in the configuration tree. Expand your RT target.
3. Right-click
Software and select
Add/Remove Software to launch the LabVIEW Real-Time Software Wizard.
4. Use the wizard to install the following components on your target:
- SSL Support for LabVIEW RT
- WebDAV Server
Configure permanent WebDAV mappings for your OS
Windows 10, 8.1, 8, and 7
Complete the following steps to map a target as a network drive and configure the Microsoft WebDAV client on Windows 10, 8.1, 8, and 7.
1. Select
Start >>
File Explorer and then select
This PC on the left pane.
2. Select
Computer from the top toolbar, then select
Map Network Drive to open the dialog box.
3. In the
Drive dropdown menu, select a drive letter to assign to your target.
4. In the
Folder text box, enter one of the following:
- http://hostname/files/
- http://hostIPAddress/files/
as shown in the preceding image, using either the name or IP address of your target.
NB: You can use NI MAX to identify the host name and IP address assigned to your target.
5. Enable
Connect using different credentials to use NI-Auth credentials instead of Windows credentials.
6. (Optional) Disable
Reconnect at logon if you do not want Windows to search for this network drive each time the current user logs on to Windows.
7. Click
Finish.
NB: If you have connected to the target using the Web-Based Monitoring and Configuration tool, you will be unable to map the target drive. Close the Web-Based Monitoring and Configuration window before attempting to map the Real-Time target's drive.
8. When prompted, enter your user name and password and click
OK. The default user name for your Real-Time target is admin and the default password is a blank password.
NB: NI recommends setting a password for improved security. As we do not store these passwords, NI cannot reset a password if it is forgotten.
Resetting a forgotten password requires reformatting the RIO.9. You can now explore and transfer files on your target as shown:
NB: If you want to navigate to your target by manually entering the target path in a browser or Explorer address bar, do not use the notation \\
hostname\DavWWWRoot shown when you connect to your target. Instead, use the notation \\
hostname\files, where
hostname is the name or IP address of the target. An example file path will look like the following: \\NI-cRIO9082-2F6137CB\files
If you have any external drives attached to your Real-Time target, they will show up as folders in the http://
hostname/files/ or http://
hostIPAddress/files/ directory. For example, an SD card or USB hard drive with the volume letter
U will be accessible at http://
hostname/files/
U/ or http://
U/.
Windows XP
Complete the following steps to map a target as a network drive and configure the Microsoft WebDAV client on Windows XP.
1. Ensure
Windows XP Service Pack 3 is installed on the computer for WebDAV to function properly.
2. Select
Start >>
My Network Places.
3. Select
Add a network place from the
Network Tasks pane.
4. In the Add Network Place Wizard, click Next.
5. Select
Choose another network location and click
Next.
6. The wizard prompts you for the address of the network place, as shown in the following image:
7. In the
Internet or network address dropdown menu, enter one of the following:
8. Click
Next.9. Click
Yes if a Security Alert dialog box appears.
10. When prompted, enter your user name and password and click
11. When prompted, enter a name for your target and click
Next.
12. Review your choices and click
Finish to exit the wizard.
13. You can now explore and transfer files on your target as needed.
NB: You may have to enter your login credentials a second time to access your target.
OS X
The following steps detail how to connect to the WebDAV server on OS X machines.
1. Select
Go >>
 Connect to Server from the
Finder menu to open the
Connect to Server dialog box.
2. In the
Connect to Server dialog box, enter one of the following in the
Server Address field:
3. Click
Connect.
4. When prompted, enter your user name and password and click
Resetting a forgotten password requires reformatting the RIO.5. Enable
Registered User.
6. Click
Connect.
7. You can now explore and transfer files on your target as needed.
Transferring Files Using WebDAV
Once you have connected to your target using WebDAV, you can transfer files between your target and development computer. Refer to the following information to learn about access permissions and the file and directory structure of your target:
Read Access
Your target provides read access to all its folders and files, so you can view files and copy them to your development computer.
Write Access
ETS, VxWorks
Your target provides write access to all its folders and files.
NI Linux Real-Time
If you want to edit or create new folders and files on your target, you can do so only in the following directories:
- /home/webserv
- /home/lvuser
- /tmp
NB: Your target deletes the content in the temporary folder /tmp on target restart.
Drag and Drop
You can drag and drop files with appropriate read and write access permissions between your development computer and your target.
File and Directory Structure
To learn about the file and directory structure of your target, see
Working with File Paths on Real-Time Targets .
Maximum File Size Limitation
The default maximum file size that you can transfer to Windows is 50MB. If you try to transfer a file larger than this, you may see:
Error 0x800700DF: The file size exceeds the limit allowed and cannot be saved.
You can transfer files larger than this by editing the registry key in Windows, as described in
Unable to Transfer Large Files Using WebDAV.
Using WebDAV via NI MAX
The following procedure works with most targets. Complete the steps to open a WebDAV session to your targets:
- Open NI Measurement and Automation Explorer (NI MAX).
- Expand Remote Systems in the configuration tree. Find your target.
- Right-click it and select File Transfer to launch a WebDAV window.
Using the WebDAV VIs
LabVIEW 2013 and later include the
WebDAV VIs to help you transfer files securely to and from a WebDAV server. You can use the WebDAV VIs to access advanced functionality such as the following:
- Programmatically store, edit, and manage documents and files on your target.
- Obtain directory and path information.
- View the progress of an upload or download request.
- Start file transfer requests in parallel.
- Process file transfer requests in response to a user interface event.
Consult the detailed context help to learn more about specific WebDAV VIs in LabVIEW, and look at the example below to see how the WebDAV VIs can work together to access files.
Using WebDAV over USB
It is possible to transfer files using WebDAV to and from a USB drive on the Real-Time Target; however, the settings will be dependent on what Real-Time OS your controller is running.
ETS
Create a new mapped network drive to http://hostname/drives/u
VxWorks
Create a new mapped network drive to http://hostname/files/u
NI Linux Real-Time
There will be a folder named U in your mapped network drive that will give you access to the USB drive on your Real-Time Target.
Note: Sometimes Linux will not transfer the files to the host PC until the references to the files are closed. If this happens, you will need to programmatically close the references to the files you are trying to transfer using the Close Reference Function.
If you are still unable to access the USB drive verify that a USB drive is connected and compatible with your Real-Time Target.
WebDAV Security
One of the principal benefits of WebDAV is improved security over the FTP server. The WebDAV server integrates with NI-Auth, the authentication service used by your target to validate login credentials. To take full advantage of WebDAV security, complete the following steps:
- Set a password for your target.
- Enable SSL on your target and specify an HTTPS connection during WebDAV configuration. If you do not enable SSL or specify an HTTPS connection, the WebDAV client transfers files without encryption.
Secure Alternatives to WebDAV
NI recommends you use WebDAV with SSL enabled instead of using the FTP server. In addition to WebDAV, you also can use the following secure options to access files on your target:
Disabling Automatic Configuration in Internet Explorer to Improve WebDAV Performance
After configuring the Microsoft WebDAV client on Windows 7, you may notice slow WebDAV performance. To fix this issue, complete the following steps to disable automatic configuration:
- Open Internet Explorer.
- Select Tools >> Internet options.
- Select LAN settings from the Connections tab to open the Local Area Network (LAN) Settings dialog box.
- Disable Automatically detect settings.
- Click OK to apply the changes and exit the dialog box.
After disabling automatic configuration, WebDAV performance improves immediately. However, with automatic configuration disabled, you may receive error messages related to file transfer failures. If you encounter this type of message, select
Try Again to re-attempt the file transfer. Alternatively, you can leave automatic configuration enabled.
Configuring WebDAV on Linux Machines
Due to the large number of Linux distributions, NI cannot provide a general set of instructions for configuring WebDAV on Linux machines. However, you can find instructions specific to your distribution on the internet.
Using Third-Party WebDAV Clients
Depending on your use case, you may find that third-party WebDAV clients offer better functionality and additional features when compared to the native client on your operating system. You can find third-party WebDAV clients on the internet.
NB: NI does not test third-party WebDAV clients, and cannot guarantee the intended user experience when using these clients to connect to your target.
