I am using the GPIB-USB-HS or GPIB-USB-HS+. Which driver do I need for the device, and where can I find it?
The NI GPIB hardware devices require the NI-488.2 driver. Use the following steps to identify and download a compatible driver version for the device:
Identify a compatible driver version.
Cross-reference driver support using NI Hardware and Operating System Compatibility and NI Driver and Development Software Compatibility.
For LabVIEW 2022 Q3 and earlier, review NI-488.2 and LabVIEW Version Compatibility.
For NI-488.2 versions earlier than 21.0, review the Supported Hardware section in the corresponding NI-488.2 Release Notes.
After identifying a compatible version, download it from the NI-488.2 Download page. Verify operating system support in the Supported OS section before installation. Use NI Package Manager to install the driver, or select Download Offline when an offline installer is required.
If you need to download NI-488.2 version 17.0 or earlier, refer to How to Download NI-488.2 Drivers Prior to 17.6 for additional information and next steps.
