SystemLink Server installs with a configuration utility that can gather the necessary files for troubleshooting.
- From the Windows Start menu, open the application NI SystemLink Server Configuration
- Start >> National Instruments >> NI SystemLink Server Configuration
- On the Troubleshooting tab, expand the dropdown menu Generate technical support report
- Check Include server logs and Include service status
- Click Generate, this will create a Zip file with all of the Server logs information
For troubleshooting purposes, it is also helpful to get logs from Client machines. Logs can be found at the following locations:
- Windows, C:\ProgramData\National Instruments\salt\var\log\salt
- Linux RT, /var/log/salt/minion
