If you ordered a Windows 7 or earlier PXI controller that was installed in a chassis by FIS:All keycodes are placed on a label on the corresponding PXI chassis. The label will be mounted on a plate such as those shown below.
If you ordered a Windows 10 PXI controller:
Windows 10 PXI(e) controllers are shipped with a preinstalled operating system where the activation key is embedded into the BIOS. Therefore an activation is usually not necessary anymore. If you are prompted for an activation key anyway, try to activate Windows 10 while the controller is connected to the internet. Also try the click the Troubleshoot wrench icon if the activation is not successful.
If your controllers were shipped with Windows 10 Pro, you can retrieve the embedded activation key by typing the following into the Windows command prompt:
wmic path SoftwareLicensingService get OA3xOriginalProductKey
As of Aug 2019, all NI Windows 10 PXI(e) controllers are shipped with Windows 10 IoT Enterprise. There is Certificates of Authenticity (COAs) that shipped with the controller that proves that there's a valid license installed. The COAs are stickers which are stuck to the side of the controller.
If activation is still not possible after trying both steps above, please contact NI support.
The key you receive for Windows 7 controllers will not actually activate Windows. This sticker is for authenticity purposes.
The OS is pre-installed on more recent controllers, most notably with Windows 7/10 OS. Therefore, product activation key is not required. If you still are still running into problems with needing to re-activate Windows than you should try to restore the OS through
Acronis True Image.
If you cannot find this packet or this sticker, please contact NI. To help us expedite getting you a product registration key, please let us know when you received your system. Also please note if the entire software packet is missing or if the packet just did not include the registration sticker.
