I downloaded the Evaluation version of LabVIEW for macOS from LabVIEW Evaluation for macOS. However, when I open a LabVIEW Project, I only see "Source Distribution" under "Build Specifications". Can LabVIEW Evaluation for macOS build an executable?
No, LabVIEW for macOS Evaluation cannot build an application. You will need LabVIEW for macOS Professional Edition to use the full functionality of Application Builder.
A valid service agreement may be required, and support options vary by country.
