The procedure to save your LabVIEW code to previous versions varies depending on: the version of LabVIEW the code was originally written in, the version you are looking to revert to, the versions of LabVIEW you have access to, and also whether you would like to revert the version of a specific VI or configure an old version for an entire project.
- If you are looking to revert code to LabVIEW 8.0 or prior versions, continue to the Archived: Reverting Legacy LabVIEW Code section below.
 - If you do not have access to the version(s) required to completely revert to your desired version, see the Version Conversion Community Forum section below.
Defining the Save Version for all VIs
Starting in LabVIEW 2024 Q3, the Save Version for all VIs feature was added, this feature allows you to use LabVIEW to edit VIs that can be opened with older versions of the LabVIEW editor. This allows you to maintain one standard old version for your project and collaborate with others who haven’t upgraded to the same version of LabVIEW that you are using. Follow the Defining the Save Version for all VIs procedure of the LabVIEW Manual.
Reverting LabVIEW Files
If you are looking to revert the version of one specific VI you can use the
 Save for Previous Version Option. You will need to open the VI in a version of LabVIEW greater than or equal to the version the LabVIEW file was initially saved in.For example, to revert a VI created in LabVIEW 2017, you will need to use LabVIEW 2017 or later in order to initially open the VI. Consider the following when using this method:
- This procedure will create a copy of the VI for the targeted old version.
 - Steps may vary slightly depending on your LabVIEW version. Follow the Help steps written for your LabVIEW version.
 - Using this method, you can save as far back as LabVIEW 8.0.
 - If you need to revert back to before LabVIEW 8.0, you will need access to multiple versions of LabVIEW to completely revert your VI. Follow the steps in the Archived: Reverting Legacy LabVIEW Code section below
If you are looking to revert code to LabVIEW 8.0 or prior versions, your destination version will not directly available in your current version.
In LabVIEW 8.0 and earlier versions, you can save for a single revision prior; therefore, you will require the use of multiple versions of LabVIEW to revert back beyond version 8.0.
In these legacy versions of LabVIEW, use the following steps to save for a previous version. This information is also available in the LabVIEW Help, available by selecting
Help » Contents and Index.
- For the top-level VI in your hierarchy of VIs, select File»Save with Options to display the Save with Options dialog box.
 - Select Save for Previous to save the VI hierarchy for the previous version.
 - Click the Save button to display the Choose a Directory dialog box.
 - Select the directory where you want to save the VI hierarchy.
 - Click the Save button.
Depending on your version destination, you may be required to repeat this process multiple times in various versions of LabVIEW.
Alternatively, the
Version Conversion section of our forum is an effective way to reach out to the community for help in reverting VI's. This is a great option if you do not have the version(s) of LabVIEW capable of opening the VI you want to revert.
See the conversion board rules, posted at the top of the Community board, for guidance on how to have your code converted.
