Log Bus Traffic with NI-XNET Bus Monitor While Running NI-XNET Application
Updated Dec 1, 2022
  • NI-XNET
Can I use the NI-XNET Bus Monitor to monitor or log CAN, LIN or FlexRay bus traffic while my NI-XNET based application is running at the same time in parallel?
This is possible when the interface NI-XNET Bus Monitor is set to Subordinate mode. A subordinate session uses the cluster and interface configuration from other sessions, in this case the user application; for more details see NI-XNET Hardware and Software Manual page 4-62. Moreover, this does not require any code to be added to the application.
Perform the following steps to configure and run Subordinate mode logging:
  1. Start the XNET Bus Monitor.
  2. In XNET Bus Monitor choose Settings menu >> Interface and Database Settings
  3. Select the NI-XNET you want to use under Interface Name.
  4. Set Run Mode to Subordinate.
  5. If you want to use a database to decode signals from frames check Assign Database Alias (opional), select your database under Alias Name and select your cluster under Cluster Name.
  1. Choose Settings menu >> Logging, check Enable logging to disk and set your logging format and destination file name.
  1. Click the Start button in NI-XNET Bus Monitor. Note that at this point logging will not yet start as the NI-XNET Bus Monitor is waiting for the application to start the session.
  2. Run your application. When the application starts communicating over NI-XNET the logging will start.
  3. Click the Stop button in NI-XNET Bus Monitor to stop logging. Note that even if you stop your application the NI-XNET Bus Monitor will keep logging and you have to stop it manually.
