Getting Started with NI-DAQmx: Transitioning from Traditional NI-DAQ to NI-DAQmx
Updated Nov 11, 2020
  • Traditional NI-DAQ
The main purpose of this tutorial is the transitioning from Traditional NI-DAQ to NI-DAQmx
Transitioning from Traditional NI-DAQ to NI-DAQmx in LabVIEW
Make the move to NI-DAQmx!  Find out tips and tricks for porting existing code from Traditional NI-DAQ.
Transitioning from Traditional NI-DAQ to NI-DAQmx using ANSI C and LabWindowsTM /CVI
Learn more in this 4-part whitepaper series about the key API and feature differences between the two DAQ drivers, and common tips for using NI-DAQmx in ANSI C and LabWindows/CVI.
Transitioning from Traditional NI-DAQ to NI-DAQmx using Microsoft Visual Basic .NET
Learn more in this 5-part whitepaper series about the key API and feature differences between the two DAQ drivers in .NET.
